  4. Erros in generated route calculations
5 Posts 3 Posters 95 Views
  • Kenneth de Mirandaundefined Offline
    Kenneth de Miranda
    The past weekend i've had two occurences that i genererated an scenic route but that MRA, after generating the route, adviced that there where errors in certain parts of the route and that it could not be calculated.![alt text](image url).IMG_6621.jpeg
      @Kenneth-de-Miranda, The message does not say that the route could not be calculated 😉 The app checks the generated track (based on OSM maps!) against the HERE map. It is just a warning that there COULD be some unwanted u-turns, wrong directions through one-way streets and similar things in the route. You can choose to look at them, or not, and continue your navigation.
      Streetpilot 2610 / Zumo 660 / Zumo 395 / CAT S52 + MRA app
      Kenneth de Mirandaundefined 1 Reply Last reply
        Kenneth de Miranda
        @Con-Hennekens ok, gotchya.
          @Con-Hennekens @Kenneth-de-Miranda next update will containing a setting to turn these checks off 😉
            Kenneth de Miranda
            @Corjan-Meijerink aha, ok!
            Kenneth de Miranda
            • Streetview
              Ruurt Visserundefined
              Ruurt Visser
            • verschil gpx bestand MRA uit windowscomputer en android app
            • Tracklog lost
              Manzo91undefined
              Manzo91
            • Automatically skipping shaping points Part 2
              Neil qundefined
              Neil q
              2.5k
            • Looks van de maps
            • Music not retuning
              NKY-Samundefined
              NKY-Sam
            • App wil vormingspunt niet verbergen
            • Tracklog anders bij gebruik als laag bij maken route
